AVS › AVS Forum › Audio › Speakers › Upgrade from BA Soundware s to Q-Acoustics 2000i series, worth it?
post #1 of 3
Hi guys,
I currently have a BA Soundware s 5.1 system paired with a Denon Avr 1912, recently i replaced the BA 200w sub with a Jamo 660 sub since it was the only thing i didnt like about the BA system, in all honesty im very happy with the overall sound since the sub upgrade, never immagined it was going to integrate so nicely with the BA sats but it actually did.
I was thinking of changing the 3 BA sats at the front with a pair of QA 2020i bookshelves including stands and x1 QA 2000ci center speaker including wall mount at a very very good price, since i havent got the option to audition them im a bit confused if i should go for the change or not. I read and have been told several times to stick with the Ba's since it wont be much of an upgrade with the QA'S, is this right? what do you think. As i said im very happy with the sound as it is, so if i upgrade its just beacuse i feel like it, you know how it is
oh and another thing i forgot to mention i use the system 100% for movies only, and sometimes a bit of gaming, cheers.
Thanks in advance guys,
Andreas
post #2 of 3
If youre happy with the soundware, but just want something better, there is the soundware XL. The 6.5" coaxial driver will give you a pretty large upgrade.
http://www.overstock.com/Electronics/Boston-Acoustics-SoundWare-XL-Speaker/3972077/product.html
post #3 of 3
  Back to Forum: Speakers
