AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › panasonic st50 breakin slide question
post #1 of 5
hey guys just bought a 55inch st50 i have the slides going right now can anyone tell me if there is a timer? i have the slides on an sd card if that helps. I just dont want to come home and se it on a menu lol thanks.
post #2 of 5
Press the MENU button on your remote. What do you see?
Have you not looked in the TV's settings menu or checked the owners manual?? wink.gif
post #3 of 5
oh we got a funny guy on here lol fine i will read the dum thing
when i press menu i get picture, audio, 3d and viera link
post #4 of 5
oh we got a funny guy on here lol fine i will read the dum thing.... when i press menu i get picture, audio, 3d and viera link
There are six menu options when you press the Menu key:
Audio
Network
TIMER
Lock
Setup
post #5 of 5
thanks i appreciate!, also i turned it over to see the basketball game (I couldnt resist) and notice the screen wil go dim and then brighten up and then dim again. i turned off the CAT setting. I dont seem to notice it on the slides if it is happening. Thanks
