AVS › AVS Forum › Audio › Receivers, Amps, and Processors › I'm new to this, i think: YAMAHA RX-V473
post #1 of 3
Here's the scoop, I use my computer for everything, no TV (I hate television but i like movies) no dvd player box, no satellite, just my desktop computer. I recently bought a laptop because I'm getting into school and I figured I would need it. I hope to build a newer desktop system since the one i have is getting pretty dated (2000).
I'm living in a travel trailer, I might get into an apartment but i don't see myself in a house any time soon. So as far as i can tell i am after a 5.1 surround system. I have used 2 speakers for my computer for years, but a while ago i went to someones house and watched a movie with surround sound and i was blown away. So i decided i wanted one for myself.
After doing some research, basically a shot in the dark because i know almost nothing about the subject, i found that the opinions on brands seem to be all over the place, but Sony doesn't sound that great in general. Onkyo and Yamaha seem to be more of a brand loyalty than any useful advantages of either one. others just seem to be pricey, not sure if i reviewed them all though.
I listen to music every day and watch movies occasionally, Im after a decent set of speakers in a budget and I guess i have to have a receiver for surround..? my computer has optical output for audio so i figured i would use it. (sounds best?) I like Pandora radio so I chose the RX-V473 based on that. From what i saw i liked the Yamaha over Onkyo. I have no experience though.
So do i need a receiver? if so what do you suggest? im not looking to spend much over $300 for the box. I also need some direction on speakers, i was thinking of a Yamaha box set with that receiver in it, but then i heard the speakers aren't the best. I'd guess at Polk RM510, that's a bit more than i want to spend, but if the sound quality is worth it then ill bite.
post #2 of 3
post #3 of 3
I looked around some more and i found this one, seems comparable:
pioneer VSX-822-K
I cant stand headphones, it seems the reciever is for amping up the power to run all the speakers? Also what should I concern myself with on the decoder support? dolby various decoders and the other one dts?
Is there a good solution without a decoder or just an amp for the speakers?
