Hi All - Looking for some advice on my first projector choice.
I think I've narrowed it down to either the Epson 3020 or the Epson 8350, but am looking for some help.
I've thought I was set on the 3020, but the input lag is really turning me off, plus I don't see myself using 3D very often.
My question is in regards to the 8350:
Thanks in advance for the help!
- Budget: Up to $1,500
- Primary use: Movies & Gaming
- Screen: Elite CineWhite 120" (1.1 gain)
- 3D not a necessity
- Gaming very important
- Some ambient light, very little
- Is the 2D picture quality of the 8350 on par with the 3020?
- Will I see a brightness difference between the 2300 lumens of the 3020 and the 2000 lumens of the 8350?
- Are there any reasons, besides 3D, I should still consider the 3020?
