AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pandora w AirPlay?
Pandora w AirPlay?
post #1 of 9
I just turned up a new Yamaha a820 and I'm trying to figure out AirPlay. My question is this can you play pandora from a connected iPad/iPhone using AirPlay? Or is it only reserved for iTunes content? I don't have much ITunes music as I primarily use Pandora for general listening, parties, work-outs etc.
post #2 of 9
You do know that A820 has built in Pandora streaming right?
I don't have any Apple devices so cant answer your question about streaming Pandora from a iPad/iPoad but I would think you should be able to do it.
post #3 of 9
I have a Denon A100 which has Airplay. Denon also has Pandora. With a iPad and Pandora I do not see the Airplay box on the screen so this is what I do to get Airplay to stream Pandora. I start by playing ITunes streaming to Airplay and then I go to my Pandora on my iPad and start playing. It catches the Airplay and plays on my system.
post #4 of 9
I know it has "Internet radio" with a million random stations...I literally plugged in yesterday and I'm still exploring. My AV guy set up tv, surround, uni-remote, and receiver. He was gone when I got home from work so I didn't get a demo.
post #5 of 9
Yo browning that worked...thanks....only downside is that the iTunes song that I started before I hopped to pandora shows up on the AirPlay interface on iPad and tv.
post #6 of 9
Glad it's streaming for you. I'm hoping Pandora can/will do a update where Airplay can be enabled instead of this work around
post #7 of 9
So how the heck do I get to the pandora & xm-sirius inputs?!
post #8 of 9
It's there.
While in Pandora on your iDevice, the bottom bar can be pulled up to reveal further controls.
To respond to the thread; I have a Denon AVR1713 and I can stream Pandora from my phone, to my receiver.
post #9 of 9
When pandora is playing press the start button twice in quick succession. You will see all the running apps. Now swipe the bottom screen twice for iPhone and once for iPad. You will see the airplay button and can playback via the receiver. This is how I am playing in HK avr1700.
