AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Amplifier Connector Bar
post #1 of 5
This is kind of obscure, but I'm trying to find some metal connector bars that go in the back of an old AVR. In the Pre Amp Out jacks. That seems to be the correct name, according to the manual. Are they one-size-fits-all, and how to acquire them?
post #2 of 5
Wont a RCA cable work instead of the "bar?"
post #3 of 5
I started wondering that a few hours ago. Does anyone know for sure?
post #4 of 5
If you are talking about the bars that go between the "pre-out" and "main-in", then yes you can just use some RCA cables with no issues. Just a little messier. tongue.gif
post #5 of 5
I've decided I should get at least one more connector bar, if possible. I just need sources. I know that old Pioneer AVRs came with them. Names of other brands that had them, please?
