Originally Posted by
ajeagle6921
az1234,
If it were your system, would you buy the Visor Control Receiver or go with iRule? I am leaning towards iRule. How hard would it be for a DIY to set up lighting zones, shades, and a thermostat? Is it very hard?
You'll need the RadioRA2 software to set up that system - talk to your dealer or go through the online courses to gain access yourself. iRule has a learning curve but it can do the trick - but it's not the total solution for all control scenarios (you'll want wall keypads, too).
The Lutron rep told me to use the RRD-6D because they were cheaper and performed similar to the RRD-6NA. Have you had experience with both?
I suspect you didn't mention that you were going to use LEDs? The 6NA is meant for LED installs with a minimum load of only 5W. The regular -6D requires a minimum load of 50W, which is a lot of LED fixtures... Lutron training folks suggest using the -6NA everywhere going forward, as even if the load is incandescent today, it will likely be LED in the near future (and could run into minimum load problems).
Jeff
