AVS › AVS Forum › Video Components › Home Theater Computers › Issue with WD Red Drives
Issue with WD Red Drives - Page 3
post #61 of 73
It must be fun to build something in a case that nice.
post #62 of 73
post #63 of 73
I'm running 12 WD Red 2TB drives in my storage server without issue. All the drives are connected to an Adaptec 5805 controller via a Chenbro CK13601 SAS expander.
post #64 of 73
I think this is some sort of strange motherboard vs red incompatibility. Needless to say we won't use this specific motherboard again with the red drives.
post #65 of 73
what is your solution ???
post #66 of 73
Going out on a limb here but I'm going to guess not to use that particular motherboard with the red drives.
post #67 of 73
Asassin,
What was your final solution ??
Change the mobo or change the drives? Or did WD come through with a fix ?
post #68 of 73
Asassin,
Changed the drives. Works well.
post #69 of 73
So now you are using more than 5 Red drives with the ASRock mobo?
post #70 of 73
No.
post #71 of 73
Originally Posted by assassin View Post
No.
So you haven't solved the issue yet...
post #72 of 73
Nope. Didn't have time to troubleshoot further. Customer wanted his HTPC.
Likely an ASRock controller issue I think. Doubt it has anything at all to do with the WD Red drives. Like I said worked perfectly well with all Greens or a combination of Red and Green.
post #73 of 73
I believe it might just be a limitation. It's probably not going to effect 99% of the people. But it does kinda suck. It's not unreasonable to want to use 5+ HDD's in a PC build and Asrock is not exactly a strange motherboard.
