I plan on powering a sub with a receiver that does not have any low pass crossover built in.
Since the receiver I am using is only a two channel receiver (connected via component output from TV), which is also powering a pair of tower speakers, I have no ability to use an active crossover; so I'm looking at a low pass filter that I can stick after the receiver and between the sub.
I ran across this, which is close to my needs (I only need something to handle around 75watts RMS; 130-180hz @ 4ohms / 250-300hz @8 ohm crossover - unsure if I will be running 8 ohm or bridging down to 4 ohm, depending what sounds best):
http://www.ebay.com/itm/Treble-Blocker-Low-Pass-Crossover-130hz-4-ohm-SubWoofer-/290420156833?pt=US_Signal_Processors&hash=item439e63e9a1
I'm going to assume those 'treble blockers' are just coils. Are there any calculators where I can make my own coils or buy a coil for a lot cheaper than $20 from maybe RadioShack? Seems a bit much.
Or does anyone have any other ideas for me? I'm looking for a fairly inexpensive solution to get my sub online.
Thanks for all the help! I will be active on responding to this thread.
Edited by WoogityBoogity - 1/26/13 at 8:52pm
