AVS › AVS Forum › Audio › Receivers, Amps, and Processors › remote app
remote app
post #1 of 5
I had the denon remote app for my ipad and it works okay. I accidentally removed it this morning. When I went to the app store to re install, it no longer shows up. Any thoughts on where to find it and re install would be appreciated.
post #2 of 5
Since you had it initially, did you sync you're iPad to your iTunes? Or back it up to the cloud?
If not, you may want to call Denon and see if they removed the app for some reason.
post #3 of 5
thanks, I will have to call Denon on Monday to find out what happened to the app.
post #4 of 5
I was able to reinstall the Denon app from the backup for my iphone. Thanks Highdefav1. I called Denon about why the app was no longer on the apple site. No good reponse other than we will look into this.
post #5 of 5
No problem...glad to hear you were able to get it back on the iPad. Peculiar why it was taken down from the app store.
