AVS › AVS Forum › Audio › Speakers › Importance of range
Importance of range
post #1 of 7
I am running Polk M30ii/CS1 front. I recently got a MS Carnival 9 Sub and love its look/feel. I was thinking of replacing the rest but the only fronts that would fit in my space are Carnival 1's with a claimed range of 90hz (m30 is 55hz). Would those speakers just be awful or can I set my crossover at 90/100 and be happy? Thanks!
post #2 of 7
I very much doubt the m30 can hit 55 hz at a decent volume.
post #3 of 7
That doesn't surprise me. Is that typical or just a Polk budget feature. I guess what I mean is would the MS 1's have a real range in the 120's or are they more honest.
post #4 of 7
What is your size restriction - and your max budget? The Polk has more boom than depth.
post #5 of 7
Size is 11.5" height. (Ouch). Which rules out all of the Polks except M30 and Tsi100. It also rules out the Carnival 2. A4L has the Carnival 1's for $120. They are sealed, 85db, 90-20khz
Figure budget is 200, less is always better. WAF is key - it has to be cherry/oak to match the sub.
post #6 of 7
The Cambridge/Mordaunt Short company - tend to do pretty good with their speaker specs.
The Carnival 1 should be decent between 100 to 120 hz.
I would still look at the Cambridge Audio S30, if you can squeeze/stretch the budget, and get
the wife approval - and if they are not going into a cubby hole. They do have good tight bass,
and plays down to 60 hz.
http://www.amazon.com/Cambridge-Audio-Speakers-Dark-Pair/dp/B004NDN9NK/ref=sr_1_2?ie=UTF8&qid=1359320645&sr=8-2&keywords=cambridge+s30
post #7 of 7
It would go into a bookcase with open back, but against a wall. Shelves are 12.5" deep. Conversely I have tons of room for the center so I might keep the m30s and get a cs2/25c
  Back to Forum: Speakers
