Currently have the Dune player and it worked with a older HP 495 with WHSv1. Upgraded to a new server with whs 2011 installed on a 128gb ssd, and 6 new HDD for my movie collection.
I installed DrivePool on the server, created a new folder for the videos, then from the Dune, had to create a new network connection to find the server and set it up using SMB. Issue is the movies don't play correctly...all blocky and stutters.
So I turned on the NFS on the server, but since it doesn't work with drive pool, had to uninstall it go with individual drives. Created the connection on Dune to the NFS folder, but videos played same way as over SMB.
So question is, what is wrong. This all worked fine on the older version just fine, but now is crap. I have to be missing something in the setup. I also thought the Dune would see the server automatically. Another issue with NFS is only able to enable it on one drive, so what do I do with the video collection on all the other drives.
Should I upgrade the Dune to a newer version or the new Met.... Player. Please, any help with this headache.
Scott
Scott
