Help with the hump please :)
post #1 of 2
Ok, still in design mode. My 1st floor has 10 ft ceilings in the bedrooms. The hallway, kitchen, and the living room has 12 ft ceilings. Thus the attic floor isn't all one height. I will have a short hallway (6 ft) leading into my theater. The floor here in the hall is about 14" taller than the floor of the theater. I want to put the door for the hall at the top of the hump. I can build a step in the theater, but don't know how practical that is. Anyone have any advice? I will attach pics of the hump and a sketch of the step I am thinking about. Thanks in advance for any advice you may be able to give.
Going in from existing room into the hall:
Looking down into theater room:
Looking from inside theater into hall:
Sketch of landing, note the door to the left:
A video of the space (4:12 has the attic part):
http://www.youtube.com/watch?v=XaFkSU1Rh9Y
Thanks again!
BD
post #2 of 2
Extend the landing out into the theater space as the riser. Side steps for the aisles to drop down to the floor level.
