AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Angled Ceiling Mount for Epson 5020UB?
post #1 of 3
Hello, I'm looking to buy my first projector and it needs to go on an angled ceiling. Does anyone have any experience with any of the following or recommend anything else for an angled ceiling installation?
Chief KITPA018024 Projector Ceiling Mount Kit (For Angled Ceilings)
http://www.amazon.com/Chief-KITPA018024-Projector-Ceiling-Ceilings/dp/B001NIEM8E
Atdec TH-WH-PJ-CM Projector Ceiling Mount
http://www.amazon.com/Atdec-TH-WH-PJ-CM-Projector-Ceiling-Mount/dp/B000ENWT1Q/ref=wl_it_dp_o_pdT1_nS_nC?ie=UTF8&colid=2Q6YWFUD8CTKW&coliid=I1T8UGRGO5X6R1
VideoSecu LCD/DLP Projector Ceiling Mount Bracket White Fits both flat or Vaulted ceiling PJ2W 1CA
http://www.amazon.com/VideoSecu-Projector-Ceiling-Bracket-1CA/dp/B000IDC0K2/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=2Q6YWFUD8CTKW&coliid=I22YN8WZKKWLE9
It's amazing how much of a price difference there is between the three. Any other suggestions are welcome. Thanks!
post #2 of 3
The Chief RPA 2500 is what came with my 6010 and it works fine on my vaulted ceiling, it's around $150. Most will have a swivel at the ceiling point attachment, allowing the mount to be placed on a incline surface. A couple more recommendations located here. http://www.avsforum.com/t/1377321/official-epson-powerlite-home-cinema-5010-6010-thread
In some respects you are paying a higher price for "name", but quality on the Chief and Peerless mounts will be higher and offer some more features/flexibility generally. If you try one that is cheaper, buy from a place with a generous return policy. As mentioned in the 5010/6010 thread a few times, the Peerless mount was found to be easy to work with, around $120 with shipping. http://www.newegg.com/Product/Product.aspx?Item=N82E16882733127
post #3 of 3
Thanks for the response. Much appreciated.
