AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › svs sb12-nsd questions
post #1 of 16
Is this sub really only 35 pounds? I sometimes hear other people talking about subs should be on the heavy side.
post #2 of 16
Do you have any reason to doubt the published specifications? This is a very well-reviewed model that has been produced for a while.
post #3 of 16
No none at all. I found one out in vegas for $300. It's just boggles my mind on how light it is.
post #4 of 16
It is a steal for $300. Grab it before it is gone.
post #5 of 16
I will get it tonight. I know it's a broad question. But between the sb12 and the outlaw lfm1-plus that I currently have. Which would produce better bass if I go dual?
post #6 of 16
One is sealed one is Ported. Two different sounds.
Depends on if you want a more musical sub or a louder deeper extending sub.
Athanasios
post #7 of 16
Had my SVS SB12 NSD for around 3 weeks and love it! Works great in my bedroom.
post #8 of 16
After setting it up using the instruction on the website. And running audyssey. The bass sounds tighter and hits harder. Music sounds awesome. Will most likely get a second sb12.
post #9 of 16
Atta Boy!!!
Nashou
post #10 of 16
This damn itch sucks!
post #11 of 16
Ya, the upgrade / need more home theater stuff never ends. Especially good subs !! Don't foget that AVS sells SVS audio too.
post #12 of 16
where? You guys have a marketplace? I only check the used classified.
post #13 of 16
Right here - http://shop.avscience.com/
post #14 of 16
Has anyone tried this sub with orb speakers? I currently have orbs own Uber 10, and I was thinking about getting a superior sealed sub for the tightness in bass. I want to know if it would be an worthwhile upgrade though considering the orb guys told me the uber 10 goes down to 21hz +-3 db while this sub goes down to 23hz. Any suggestions would be appreciated.
post #15 of 16
Read the SVS SB12 review on audioholics, then go and buy it...best audio purchase i have made, once i sell my Epik Legend i will be buying two more for my main room tongue.gif
I question the uber 10 going down to 21hz.
post #16 of 16
I don't know much about Uber-10 but I own one of these SB12 SW. It is very musical and tight. For music I doubt you will need to go down that low anyway. Also it is ideal for small/bookshelf speakers as its freq range is wide (I think upto 260Hz). I have AG Stradas (LRC) XO @120Hz.
Depending on your room size you may need different configurations. I had a SVS dealer rep visited my house to test out different combinations a while ago. Consider
1 x SB12 --> Small to medium size room (say, up to 4 x 6m)
2 x SB12 --> Big room, or
1 x Sb13 Ultra --> Big room
my 2c
