I just purchased an Onkyo ht-s5500 HTIB. This is my first venture into true home theater. I read all the negative reviews about the 5500's sub failure and Hdmi problems but the referb from A4L was the best system I could afford . I realize the speakers are not great but will be a Hugh improvement over my old Koss 6.1 "system"
But there-in lies my problem. I am only hard wired for 6.1 rear surround that I cannot easily change. But I could easily add 7.1 configure with front high
Options:
The way I read the manual for the Onkyo ht-r591receiver is that it can be wire with a single or dual rear surround or front high.
So would I be better going with a single rear 6.1 surround speaker ... OR ... 2 front high speakers in a 7.1setup?
Also, I see nothing about front wide for the Onkyo receiver that comes packaged in the ht-s5500. So I guess it will not support front wide only front high (the terminals are labled rear surrond or front high).
So if I go front high, do my highs need to be directly over the frt mains or can they wide out on the wall to the corners? That would place them 12ft apart with the mains being 4ft apart.
Room is 12x16 and the wall is 9 ft hi. TV is on the 12ft wall in center.
Thanks for your help.
Options:
