AVS › AVS Forum › Video Components › Home Theater Computers › Lock screen and plex server issue
post #1 of 2
I have my htpc connected thru hdmi to my receiver then to my tv. If I change inputs on my receiver and keep the htpc running it goes to a lock screen because it doesn't sense a monitor. Problem is I need to keep it running so others can use the plex server. Is there a way to eliminate the lock screen?
post #2 of 2
Odd, I don't think Windows normally logs you out if the monitor turns off. Do you have a screen saver enabled? Also, in power settings in the Windows control panel, do you have "require password on wake up" enabled?
