I'm likely going to sign a contact to build a new home a home builder soon (maybe even tonight). I can provide the builder if anyone wants to know.
I'm paying for the full basement, and 9' ceilings (9' sounds sweet, right?). Does anyone have any advice with anything else to look out for? Anything to request before signing the contract?
Unfinished portion of the basement I'd like to use is around 17x23.
I've asked questions about moving some things, like HVAC a foot or two, and generally any changes that I've asked for are met with "well, no, but maybe that could be a custom change that would cost $).
In the past, they've used wood I joists where they can run ducts through them, but because of some code changes, they're going to need to use LVL joists where they can't do the same thing. I'm concerned about vents draping underneath the beams now, but I guess not much I can do (move them later, I guess).
I'm just looking for someone to say "bigger room.... high ceilings.... new build....sounds good....... OR "make sure to look out for xyz".." I keep feeling like I'm overlooking something major??
Here goes anyway:
If the other beams are 20" but a 10" steal beam will do the trick, you could route your mechanicals under that to get into the room. Again, it would be nice to talk with a floor designer about what you want, and let them try to figure out another approach.
