Okay so when I built my htpc I learned that you don't need cutting edge stuff to accomplish it and probably spent 1K instead o1.5K and I could have done it for even less if I wanted.
So a friend inspired by me getting a custom built PC decided he wanted to do the same for gaming at highest settings and hopefully with some longevity.
We took a look at recommended specs for Skyrim as a starting point as that's a game he wants to play.
He currently has a PC but wants one that can play games at 60 fps at the highest settings.
So the debate here is does a person need an i7 or an i5?
And should one go higher than the GTX 660 Ti range? Am I right to say going beyond that price and performance point is for 3d high setting gaming and resolutions beyond 1080p (both of which are moot points for my friend)?
Guess the shocking part is that with his old case, power supply plus buying
a cpu, 2 x4 gb ram, 256 gb ssd, 1 tb hard drive, motherboard, graphics card the parts will cost around 1K. But if you look at those places where you can custom build a gaming PC the costs can be upwards of 2K.... are we missing something?
