i have a question, this type of material is oke or not for dedicated hometheatre?
and for buying
http://www.ebay.com/itm/Silver-Grey-Black-Stria-Stripe-Wallpaper-Modern-Striped-Vinyl-Wallpaper-29540-/221136999462?pt=LH_DefaultDomain_0&hash=item337ccad426
i m planning to paint ceiling and behind the screen wall with black flat paint
and this material is for side walls
what do u think?
I also got a reply from manufacturar
I finally found the copy of my book that this comes from. There is no silver in it like I thought there was. It is just black and grey. Unfortunately this paper does has a slight satin finish so it is reflecting a small amount of light. If you have your heart set on this one, I would suggest that you order a sample.
Cheers
Cem
Edited by cemo62 - 2/1/13 at 1:34pm
