I don't even use all that clone power but it does not rolloff at high levels so if this berry can do that then it seems like an awesome alternative.
post #61 of 146
1/30/13 at 8:34am
3000 watts per in 4 ohm stereo, peak is what they are showing in the link for the 12k. It almost seems like they are just beefing up the power supply(s) in the 6000 to make it 2 ohm stereo stable.
Then perhaps plan on buying a new fleet every three to five years because the cheap electronics they use, that they found in the bargain of the month bin, aren't worth replacing the entire guts of the amps with.
