Ive decided to go with the Kef T305 speaker system for my new movie room. I have a noob question I was hoping somebody could please help me with. I want to set up a 7.2 system, I see the surround speakers for the T305 system are the T301's, and the center speaker for the system is the T301c.
Both speaker types seem to me to be identical in all ways except that the surround 301 hangs long ways up (vertical), and the center 301c hangs long ways side to side (horizontal). Could I use the center speaker (301c) as surround speakers? I have an open doorway directly to the right of my seating area so there is not a place to hang the surround 301 speaker, however there is a 12" soffit along the ceiling that would allow me room to hang the center 301c speakers from. I would angle the speaker down toward the seating area. So in short I am hoping I can use 2 of the center 301c speakers in place of 2 of the the surround 301 speakers.
Thank you.
Model T301
Design Two and a half-way closed box
Drive units 2 x 115mm (4.5in.) dual layer MF
25mm (1in.) aluminium HF
Frequency response 80Hz - 30kHz
Crossover frequency 1.7kHz
Amplifier requirements 10 - 150 W
Sensitivity (2.83V/1m) 88dB (floor stand mount)
Maximum output (SPL) 110dB
Impedance 8Ω
Internal volume 1.4 Litres
Weight 1.5kg (3.3lbs)
Dimensions (H x W x D) 600* x 140 x 35 mm
(23.6 x 5.5 x 1.4 in.)
Finish Black
Model T301c
Sensitivity (2.83V/1m) 91dB (wall mount)
Impedance 8Ω
centre mode 140 x 600 x 35 mm
(5.5 x 23.6 x 1.4 in.)
Finish Black
Thank you.
Model T301
Impedance 8Ω
Finish Black
Model T301c
Impedance 8Ω
Finish Black
