The DLA-RS50U 3D Home Theater Projector from JVC is a 3D-enabled 1080p home theater projector. The DLA-RS50U has a brightness of 1300 lumens. The DLA-RS50 is 3D compatible. JVC uses frame sequential method, which provides a full 1920 x 1080 pixels to each eye without crosstalk and flicker.
The DLA-RS50U is built around an optical engine that produces brighter images with even higher contrast than previous models. An upgraded wire grid polarizer reduces stray light caused by reflections and helps increase the native contrast ratio to 70,000:1.
My personal projector used in our Great Room theater.
250 hours on it.
Complete with 2 pairs of 3D Glasses and IR Emitter.
The projector is a D-ILA projector. This is characterized by natural pixel-free film-like images with smooth gray scales and highly accurate colors, thanks to tightly-spaced pixels and liquid crystal blending.
Lastly, the DLA-RS50U features a motorized lens cover which opens and closes in synchronization with power on / off to protect against dust, so even if the projector is installed up on the ceiling, you are assured of easy, trouble-free operation via the remote control.
Product Highlights:
1300 ANSI Lumens
1920 x 1080 Resolution
D-ILA Imaging Technology
70,000:1 Contrast Ratio
7-Axis Color Management System
3D Capable
120Hz Clear Motion Drive
Motorized Lens Cover
Inverse Telecine (Reverse 2-3 Pulldown)
THX 3D Display Certification
$1,900.00 shipped. US only. PayPal - Shipped to address on pp account.
250 hours on it.
Product Highlights:
1300 ANSI Lumens
3D Capable
