Hey folks, I currently have a bedroom setup with a sub, running a cable from the sub out on AVR to Left (mono) input on my Energy sub. I was wondering if I can use another cable to run from another audio device into the Right sub input and use the sub with this other device in this way? In other words, can I use my sub with 2 different devices, one connected to the Left (mono) input and one into the Right input? I wouldn't use both the AVR and the other device at the same time. Could this be hazardous to my sub? Would it even work? Was thinking of setting this other device in the same room and wanted to use the same sub. I could always run a cable from the AVR and the other device and just switch out the cables into the Left (mono) input on the sub, but it would be nice if I didn't have to keep switching the cables. I guess it boils down to whether or not the Left and Right sub inputs do the exact same thing, or is the Right supposed to be used in conjunction with the Left (mono) input to work correctly, say for instance using a splitter? My sub is the Energy S10.3. Thanks for any advice.
AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Using Left And Right Inputs On Sub For Two Different Devices?
AVS Top Picks
