AVS › AVS Forum › A/V Control & Automation › Remote Control Area › How do I control Somfy RF with iRule?
post #1 of 2
Anyone done this before? I have 9 somfy RF roller shades? Had 1 person tell me that I have to purchase a $500 controller to perform this. Hoping there is a cheaper workaround. Thanks in advance for any help.
post #2 of 2
Integrating a standalone RF system is always a challenge. I don't have an answer to your specific question, but it did get me noodling on the topic of any viable alternative approaches: Depending on the price/availability of the Somfy RF remote + your comfort with pulling one apart and tinkering, you could consider doing something similar to this:
http://www.avsforum.com/t/1300232/ir-control-for-rf-devices
You basically use the Velleman IR switching kit (which is really easy to put together) to emulate button pushes and control it using a standard emitter/blaster with iRule
....I don't know the number of buttons on your remote, but you could also maybe use iRule to control the open/close contacts on an iTach or GC-100 to simulate button pushes....just a thought.
Dave
Edited by DGF - 1/30/13 at 12:45pm
  Back to Forum: Remote Control Area
