This might be a bit overkill as I am already using a quality APC UPS for my gear.
However, I thought it still makes sense to add a bit extra protection. Further, my dimmer can cause my APC to make some noise. I tested several dimmers and the one I am using caused the least noise.
Has anyone come across the surge protector/noise filter combos?
I found the Leviton 5280. Are there better ones?
