I just ordered an ACER H5360. For the time being, I am just going to have to paint my wall for the screen. Right now the wall is painted black, and has "Orange peel" texture.
If it matters, I will have total light control. The side walls are a "Mocha" color, and the ceiling is still white. It will be mostly used for movies, 3D movies and sports. No television watching.
My question is, which brand/color paint would you guys recommend? And is the orange peel texture a problem? Pretty stoked to have my first annual super bowl party!
Thank you for your input!
Shane
Shane
Take a picture of the screen in bright, normal light (...but non-direct...). I'd like to see how dark of a Gray they mixed up for you. Check your Lamp Mode. If the PJ seems "dim" to a fault, far dimmer than you were expecting, it probably is. Use it tomorrow, and see if things change, but minimize hours used, and on Monday call & explain and request an exchange.....at minimum.
