My current Pioneer vsx816 is starting to cut out my center channel...plus it doesn't have hdmi. I'm partial to Pioneer but open minded to other brands. I would like to be in the $200-$300 range but can spend more if I feel it fits my needs better. I'm also looking to upgrade my speakers. I will be running some large bookshelf speakers or maybe satellites...no towers. ALL opinions and comments are welcomed...so let me have it. Thx, Jerry
Featured Stories
Related Forum Threads
- Onkyo TX-NR616 for sale Last post on Today at 5:22 am in Audio Gear
- Onkyo TX-NR 626 Bluetooth in zone 2? Last post on 5/6/13 at 10:20am in Receivers, Amps, and Processors
- Onkyo TX-nr616 -- Zone 2 Last post on 5/4/13 at 8:20am in Receivers, Amps, and Processors
- YAMAHA AVENTAGE RX-A820 vs Onkyo TX-NR616 or other suggestions Last post on 5/18/13 at 9:20am in Receivers, Amps, and Processors
- HK AVR-1700 or Onkyo TX-NR616 (Need Help Today!) Last post on 5/3/13 at 8:25pm in Receivers, Amps, and Processors
Time to upgrade my receiver
Gear mentioned in this thread:
post #2 of 23
1/29/13 at 2:36am
- WagBoss
- Trader Feedback: 0
- offline
- 579 Posts. Joined 1/2012
- Select All Posts By This User
- BlakRam
- offline
- 45 Posts. Joined 1/2012
post #4 of 23
1/31/13 at 5:08am
- BlakRam
- offline
post #6 of 23
1/31/13 at 8:06am
HDMI pass-through means you can have your receiver off but it still allows the picture to go through. So basically you can watch TV and use your TV speakers with your receiver being off.
post #7 of 23
1/31/13 at 8:09am
- afrogt
- offline
- 19,891 Posts. Joined 7/2003
It allows you to use the TV speakers when the receiver is off (actually in standby mode). Some people like to do that at night when watching TV while everyone is asleep. You can use an HDMI device like a cable/sat box and it will pass thru the audio and video signal to the TV while the receiver is in standby mode.
Is that what you're asking?
post #8 of 23
1/31/13 at 8:09am
- WagBoss
- offline
yeah, it's also called hdmi passthrough, where you can watch tv with your receiver turned off, and yes the sound comes out of the tv.
- BlakRam
- offline
post #10 of 23
1/31/13 at 8:36am
- commsysman
- Trader Feedback: +1
- offline
- 3,524 Posts. Joined 12/2007
- BlakRam
- offline
post #12 of 23
1/31/13 at 11:33pm
- WagBoss
- offline
- BlakRam
- offline
I may have the chance to get an old Yamaha 861 for $75. Anyone familiar with this AVR? I believe it makes good power. Only has 2 hdmi but that is all I need right now. I don't think it has any networking features, airplay or 3D. How would 3D work on an AVR that doesn't support it? What does a 3D AVR really do?
post #14 of 23
2/1/13 at 9:38am
- WagBoss
- offline
a "3d avr" just lets you input a 3d blu-ray player with hdmi and then it lets the 3d through the hdmi output and onto your tv. if you have a 3d tv and blu-ray player, and your avr doesn't, then you just put the hdmi from the blu-ray directly into the tv, and use the optical output of the bluray playe for audio. if you don't have/ don't watch 3d, then it doesn't matter.
that receiver doesn't do dolby truehd or dts hd, but for 75 bucks it's a very good deal.
- BlakRam
- offline
post #16 of 23
2/1/13 at 10:45am
- WagBoss
- offline
- BlakRam
- offline
post #18 of 23
2/8/13 at 8:30am
- Bud B
- offline
- 653 Posts. Joined 2/2009
Hi BlakRam,
Just for the record: I do think that the VSX 1122 is worth the extra $100.00
If you don't think so go here and look at the comparisons: Click on the 1022 and the 1122 and then click compare
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/ch.Pioneer+Receivers.Compare
Also the VSX 1122's Product Sheet shows in Bold Black the upgrades from the 1022 and that's here:
http://www.pioneerelectronics.com/ephox/StaticFiles/PUSA/Files/Home/VSX-1122-K%20New%20Single%20Sheet.pdf
The VSX 1122 also has five "Assignable" HDMI's, the Elite VSX 50 and VSX 1022 have none.
If your question was the VSX 1122 or the Elite VSX 50, hands down my answer would be the VSX 1122 and load the Warranty.
But with the VSX 1122 @ $600.00, I would spend $50.00 dollars more and get the Elite VSX 60 @ $650.00, load the Warranty and go home.
I'd also put my purchase on my BB Card and get 18 months same as cash!
For the extra $50.00 I get a 2 year Warranty, Extra Features and I just think that the Elites are made Better.
The VSX 1122 compares closer to the Elite VSX 60 and is a better comparison.
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/VSX-60
One thing that you can do is go to Pioneer and look at the Specs of each.
I have Mozilla Firefox and Internet Explorer so I could open the Spec of each and compare side by side.
Pioneer does not always make this easy as they jumble things around a bit.
Here is a link to the Elite VSX 50: http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/VSX-50
Click on the Product Sheet and look at the back looks much better than the VSX 1022.
Not that looks are everything but it does say a few things as to build.
Here is a link to the VSX 1022: http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Pioneer+Receivers/VSX-1022-K
VSX 1022 Product Sheet:: http://www.pioneerelectronics.com/ephox/StaticFiles/PUSA/Files/Home/VSX-1022-K%20New%20Single%20Sheet.pdf
You can see overviews, Specs, OP Manual, etc of each.
A few things to note between the two receivers:
The Elite VSX 50 has 4 HDMI Inputs and the VSX 1022 has 6 HDMI Inputs....How many external devices do you need to connect today and in the future to your A/V receiver.
On My Elite VSX 53, (Living Room) I'm using 3 HDMI Inputs: Computer HTPC, DIRECTV, Blu-Ray player.
On my Elite VSX 60 (Bedroom) I'm using the same : HTPC, DIRECTV and DVD Player / Burner
So that's 3 HDMI's on each, with a game console that would be 4.
The Elite VSX 50 has a Pioneer 2 Year Warranty compared to the VSX 1022 with 1 Year.
The Elite VSX 50 has 6 MCACC Memory locations compared to 1 for the VSX 1022.
The Elite VSX 50 lists supported Apple Devices as: 4th gen Nano and above / iPhone, 3G, 3GS, 4 / iPad, iPad2
The VSX 1022 lists it's supported Apple Devices as: iPad 2, iPad, iPhone 4S, 4, 3GS, 3G / iPod touch 4G, 3G, 2G, 1G / iPod classic / iPod nano 6G, 5G, 4G, 3G
So this depends on your Apple Needs.
This also shows on the spec page, I would suggest reading the OP Manual and delving further if this is an important spec for you.
Just because it is not listed on the Elite VSX 50 Spec page does not mean that it has it or not.
It really depends on your needs of the receiver.
If I was you I'd download the two Operator Manuals and give them a once over, checking features that really apply to you
Myself, I like the Elites, but the 50 is an older Elite and why BB is selling it out.
The 1022 on the other hand is current and why it has the newer Apple Devices Spec.
With either purchase I would highly recommend the "Extended Warranty" for as long as you can!
I had a VSX 1020 die on me out of Warranty and it took a lot to get Pioneer to swap it out.
Pioneer gave me choices on any current model as a replacement, with a much reduced costs than retail.
I chose the Elite VSX 60 and I have been very happy with it!
A Warranty would have helped me a lot and at the time for a VSX 1020 I think it was around a hundred bucks.
It would have been the best hundred bucks I'd spent.
So that may sway you, the Elite VSX 50 at $250.00 plus Extended Warranty or the VSX 1022 at $450.00 plus Extended Warranty.
Does the VSX 1022 have three hundred dollars worth of features over the Elite VSX 50? That's a question that you will have to answer.
I really like the Elite VSX 60, so far so good.
Given your comparison of the VSX 50 or VSX 1022, I'd get the Elite VSX 50 and put the Extended Warranty on it!
But that's just my opinion and specific needs.
You need to determine the same for you.
Good Luck,
Bud B
PS. I am assuming that the "Open Box" has all of the accessories like a remote, (you can download the Manual) and comes with a full 2 year Warranty.
Edited by Bud B - 2/8/13 at 9:17am
You saw the VSX 1022 for $250.00 @ BB?I just missed the $200 HK1700. I guess I now will go with the Pioneer 1022 for $250. I don't think the 1122 is worth the extra $100.
Good Luck,
Bud B
post #19 of 23
2/8/13 at 1:20pm
- WagBoss
- offline
- BlakRam
- offline
Bud...thx for the info.
This is what I've found:
open box vsx50 $250, new vsx1022 $248.88, new vsx1122 $349.99. I was going to have BB price match the 1022 or 1122 if I go with one of those. I'm now definitely set on one of these 3 AVR's due to price. I plan on building my home theater down the road and at that time, will drop a few bills on a new system. I currently run a PS3, Directv and maybe a PC down the road. I plan on wiring the AVR, so WiFi is not needed due to the extra $$$ for the adapter. The last thing I'm considering is the cool things I could do with my Android tablet or iPod touch??? I will pass on the warranty, I never buy them. Looks like the vsx50 is missing the remote, even though the sticker says no accessories are missing...might be able to get the price dropped??? I have a Harmony 880 remote that I haven't used in a long time.
post #21 of 23
2/9/13 at 12:09am
- Bud B
- offline
Hi WagBoss,
Live by it and eventually Die by it!
In the old days when electronic equipment was built like a tank, I agreed!
Today unfortunately they are not, we live in the Throw Away, Buy New but don't repair Millennium!
I had a 2 year old VSX 1020 that would turn itself on and off, lose HDMI, etc..etc..etc...
I took it in to Pioneers Authorized repair facility (Out of Warranty) it cost me $50.00 (half of what a 4 year Extended Warranty with BB would have been) for them
to look at it but the $50.00 would be applied to the repair should I decide to repair it!
After having my 1020 for almost 2 weeks, the result was that it is too infrequent of a problem to completely diagnose
but after conferring with Pioneer they determined that it was most likely the main control PCB and if "Under Warranty" they would have just replaced it.
BUT because it's not, I could choose to replace the Main Control PCB at a cost of $525.00.
Then again because I had numerous problems it was probably more than just that one part.
WHAT DID I WANT TO DO?
I took it back and went home, plugged it in on my kitchen cabinet and it immediately turned itself back off.
I took it back, they had it for another 2 weeks and came back the same result and again they were not able to completely diagnose the exact problem.
I took it back and started my discussions with Pioneer.
I told Pioneer that their repair facility could not find the problem, it would be one thing if they did and gave me a repair price and it was up to me, but instead I am left in limbo!
After sending all paperwork and emails back and forth including a video of what it did, I finally was offered a replacement at a lower cost.
Bottom line...I have paid out $750.00 in 2 years and over two months of frustration when $600.00 ($500.00 + $100.00 for Extended Warranty) would have gotten all my troubles taken care of.
Not to mention that I would not have had to listened to my HDTV's tiny speakers throughout the whole process!
Have you ever heard the expression that hindsight is always 20/20, I would have gladly paid the $100.00 Extended Warranty when my receiver went down,
BUT like you, I didn't get the "Extended Warranty!"
I do now!
Let me ask you a question, If you paid $500.00 for a new electronic device, like an HDTV, Receiver etc and after it's 1 year Warranty, it dies,
Will you just gladly walk out and just shell out another $500.00 and buy another unit?
You now have $1,000.00 invested when you could have just paid $600.00 with the "Extended Warranty" and you are back up and running.
I bet at that exact moment, you would have given anything to have a hindsight 20/20 moment, and had actually paid the $100.00 for the "EW"
You would be able to get your unit fixed (just be inconvenienced for the repair time) and so happy that you were so smart and saved $400.00
I just had a Panasonic TM700 HD Camcorder that went down over Christmas at my sisters.
When I got home I scrambled for the receipt and was saying to myself, "Please tell me that I took the Extended Warranty and it had not expired!"
Thankfully I took out 4 years of "EW" ($99.00) and it expires in October 2013! I was saved! Thank Me, Thank Me, Thank Me!
You can read through these forums and see that literally every manufacturer, has equipment that goes awry.
No rhyme or reason, it just does, the proverbial Sh_it Happens!
It's Health insurance for electronics!
Unfortunately I have learned that it is a new Millennium thing!
When it hits you just once, you'll be nastily converted!
I wish you luck though!
Bud B
never get extended warranties in my opinion.
I do now!
Bud B
post #22 of 23
2/9/13 at 12:19am
- Bud B
- offline
- BlakRam
- offline
- Time to upgrade my receiver
Currently, there are 1978 Active Users
(559 Members and 1419 Guests)
Recent Discussions
- › DIY Custom-Printed Movie Poster Acoustic Panels - cheap! 33 seconds ago
- › Official SVS Owners/Support Thread. 46 seconds ago
- › Dancing with the Stars...on ABC...in HD! 55 seconds ago
- › Power Sound Audio Discussion Thread! 1 minute ago
- › *Official* Roku 3 Streaming Player Thread 1 minute ago
- › Panasonic ST60 vs. Samsung F5500 1 minute ago
- › Sony KDL52XCR3 - Sound but no Picture... 1 minute ago
- › Hot Off The Press: The Latest TV News and Information 1 minute ago
- › West Palm Beach, FL - HDTV 2 minutes ago
- › Official Panasonic VT60/VT65 Series Discussion Thread [No Street... 2 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
