Here is the layout I am considering.
Could I use ½ or ¾ inch square metal tube laid in a notched channel in the flooring to run electrical from a circuit in the wall? It would be ridged enough to hold up especially supported by flooring. It is thicker than electrical conduit. It appears code allows conduit for exposed runs but I didn’t see limitations to elevation or flooring. My other issue is once I get it to the bar or wall, do I need to continue sheathing to receptacle or junction box? Here is a link to what I am referring to.
http://www.homedepot.com/h_d1/N-5yc1v/R-100337410/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=square+metal+tube&storeId=10051
