AVS › AVS Forum › Audio › Speakers › A new 3.1 system
A new 3.1 system
post #1 of 11
My set right now is Panasonic GT50 55", Denon 2112CI, OPPO 103 Blu-Ray player, 2 older Polk floor speakers, older Polk center speaker, and Klispch 10" subwoofer. My room is about 12x15 and we sit about 10' from TV. With the configuration of the room the TV has to sit at an angle next to the fireplace with the 2 floor speakers on each side. I don't want a 5.1 system, but I am trying to figure what might be some options to update my 3.1 system. I am thinking of some tower speakers, but I don't want them too ultra tall. Also, is it best to also get a new subwoofer?? I don't want to go over $500 for the system. Am looking for the best quality audio at that price point. Any suggestions?? Thanks!
post #2 of 11
Exactly what model speakers do you have?
For $500, you may not be able to do much of an upgrade.
Maybe the best upgrade at this point would be a Polk PSW505 sub.
Edited by commsysman - 1/29/13 at 7:16am
post #3 of 11
The model of the 2 Polk speakers is S8.
post #4 of 11
Well, perhaps a pair of Polk R300 speakers and a Polk CS20 would be a step up; you could do that for under $400.
Polk describes the S8 as a bookshelf speaker on their website (although it is 3-way and a bit larger than most).
post #5 of 11
The S8's are 25" tall and 9" deep and they sit on the floor on each side of the TV. The center is a Polk C150. Are Polk the best I can go for that price range?? I could push my limit to about $700, but that would be it.
post #6 of 11
At $700, you might go for a set of Infinity Primus, specifically the p363 towers and a c351 center. I think that would be a very tangible upgrade over your current speakers.
post #7 of 11
Polk or Pioneer's speakers are the best in your price range
BTW's the Polk R300 and CS20 center don't match and aren't even sonicly close so I don't know why the person above is recommending them rolleyes.gif
Here is one sugggestion from me:
-Polk Monitor 25c center, $150 (http://www.newegg.com/Product/Product.aspx?Item=N82E16882290274)
-Polk Monitor 75t towers, $220 each with discount code 'EMCXWVL65' until 2/4 (http://www.newegg.com/Product/Product.aspx?Item=N82E16882290272)
Another suggestion:
-Pair of Polk RTi8's for $400, http://www.ebay.com/itm/EA-RTi8-BLACK-Floorstanding-Tower-Speaker-Polk-Audio-/230882604738?pt=Speakers_Subwoofers&hash=item35c1acf6c2
-Polk CSi5 Center for $225, http://www.ebay.com/itm/CSi5-BLACK-Center-Channel-Polk-Audio-RTi-Series-Speaker-/360504632120?pt=Speakers_Subwoofers&hash=item53efc02338
Edited by crazyrob425 - 1/29/13 at 7:58am
post #8 of 11
I would recommend waiting on the sub. If you have a 10" sub like the Klipsch SUB-10, you'll probably need to spend $300 or more to get a significant upgrade over it. You'd be better to put your money towards speakers and wait and get a new sub later on.
The Infinity Primus and Polks mentioned are both good choices. Also look at these Boston Acoustics:
http://www.accessories4less.com/make-a-store/item/BOSA360WHA/BOSTON-ACOUSTICS-A360-3-Way-Dual-6.5in-Tower-Speaker-Each-White/1.html
http://www.accessories4less.com/make-a-store/item/BOSA225CGBA/BOSTON-ACOUSTICS-A225C-2-Way-Center-Channel-Speaker-Black/1.html
post #9 of 11
Another suggestion:
Thanks for the suggestions.......would I also need to replace the Klipsch subwoofer?? I bought the Klipsch only 2 years ago and it seems to fit in well with my current setup.
post #10 of 11
With your budget I wouldn't.
You need at least $300 on a subwoofer for any improvement but once you get to $500 you'll be able to make a huge step up. If the Klipsch 10" is meeting your needs I would keep it
post #11 of 11
+1
For $300, you could catch the Klipsch RW-12d on sale at Newegg if you watch for it. If you have the Klipsch SUB-10 I previously mentioned or the RW-10d, the 12" would give you more output for HT usage and a little bit deeper bass, but the more significant upgrades come from spending $500 or more where you get better SQ as well.
However, there is one option. If you can find the exact same Klipsch sub model, dual subs would smooth the bass frequency response in your room. Does sound better. But generally, it's best not to mismatch subs in a dual sub setup.
Which Klipsch do you have? Newegg has the SUB-10 on special for $169 through tomorrow (promo code EMCXWVS95). That would be a wortwhile upgrade for that amount. But otherwise, wait until you can spend more.
  Back to Forum: Speakers
