So although I was willing to spend a few (read: $200 or less) on a fixed screen I could simply hang from my ceiling in front of THIS:
...I'm quickly discovering (so it seems, anyway) that fixed screens in this $-range REALLY want to be mounted on a wall to stop the flexing they all seem to endure when the fabric is tensioned (if anyone is aware of an option in this $-range that DOESN'T, please advise
SO then, I'm reconsidering DIY, but have a "thought" (I'm sure someone has done it before) of an alternative to stretching the fabric over/around a typically constructed wood frame (read rectangle with internal bracing).
Thought: can someone simply construct a frame out of 1x3 (braced), then stretch the fabric across its outer dimension, staple/adhere the fabric, cut off the excess (within the ID of the frame) and simply "sandwich" it (the fabric) between another layer of 1x3?
With adequate clamping and some titebond around the outer edge, seems to me you could form quite a robust, but light, frame/screen.
Further, it appears that this would eliminate all of the sometimes kludgy, sometimes VERY irritating stretching around the frame- especially so at the corners.
I realize this may require a very judicious selection of lumber for the frame (for the sandwich element to work well), but you should really be doing that anyway (my screen is "only" 86" so I'll only have ~ 6 1/2' spans).
Reasonable approach?
thanks!
James
Edited by mastermaybe - 1/29/13 at 8:17am
).SO then, I'm reconsidering DIY, but have a "thought" (I'm sure someone has done it before) of an alternative to stretching the fabric over/around a typically constructed wood frame (read rectangle with internal bracing).
thanks!
James
So that's not happening.
