AVS › AVS Forum › Video Components › Home Theater Computers › Case for HTPC Build w/h Micro ITX Mobo and PC Power Mk III Modular
post #1 of 6
I'd like to get some input to finish up a HTPC build. My main concern is finding a good case that will fit the PSU 150 x 160 x 86mm (and HD, Blu Ray drive, etc).
Normally, I'd select the case first, but circumstances... I ended up getting the internals first because I pulled the trigger on some great $ deals.
PSU: PC Power and Cooling Silencer Mk III Series 400W Modular
Mobo: ASRock H77M Mini ITX
SSD: OCZ Vertex 4 VTX4-25SAT3-128G 2.5" 128GB SATA III MLC
HD: one 3.5" to be purchased
BD/DVD Drive: to be purchased
This case is going into an entertainment center next to several standard black AV components.
I had my head set on a horizontal HTPC case, purely for aesthetics. However, I'm realizing now that the case will likely be close to the sides of the rack walls, and may not get sufficient air flow. Plus, I'm reading that some of the horizontal HTPC cases with 80 mm fans can be noisy. However, maybe this build will run cool enough where I don't have to worry to much about the side air intake?
I'm now considering mini-ITX tower and micro-ATX cases. Seems these might be a win-win, as they'll still look ok in my entertainment center, and if I ever re-purpose the PC, the case will be a small "desktop" system.
Requirements:
Budg
  • et: $130
  • Fit: PSU (150 x 160 x 86mm), BD/DVD, HD, SSD
  • Dimensions: 18 inches height, width: standard AV/component
  • USB: 3.0 ports? My mobo supports 3.0, should I care about 2.0/3.0 in front ports for game controllers?
  • Front access for BD/DVD Drive
  • Quite Fans (prefer 120+ mm over 80 mm)
  • No bright lights
Vertical Cases
Fractal Design Arc Mini w/ USB 3.0, 19" height!
Fractal Design Core 1000 Micro ATX Computer Case w/ 1 x 120mm fan USB 2.0, 16.5" height
SilverStone Temjin Series TJ08B-E Black Aluminum front panel, steel body MicroATX Mini Tower Computer Case, 15" height, USB 3
SilverStone Sugo Series SG09B Black Steel / Plastic MicroATX Mini Tower, small! 8.66" x 11.61" x 13.94"
Horizontal Cases: (the typical list)
SILVERSTONE Grandia Series GD05B
mMediaPC.... etc.
Thanks in advance for your input.
post #2 of 6
My Antec Fusion Remote has a bright led around the power button.
The Core 1000 should meet all of your requirements and save you some money.
I wouldn't worry about usb2.0 vs 3.0.
What CPU are you using?
GPU wanted?
post #3 of 6
looks like a nice build... I like the PSU/SSD/Motherboard... combo.
Good taste.
How about the other parts?
post #4 of 6
I got the i5 3570k Microcenter / mobo deal. I know I'm spending $ on this build, but I'm using it as a Plex server (transcoding) and also I'm the type of person to overbuild things and leave it alone. ... how I've changed since my overclocking days < kids... rolleyes.gif
BD/DVD: Just need something basic..
HD: looking into WD Green/Red, and Samsung. Was thinking eventually of building a Flexraid server, but that'll be a later project.
Remote: Have a Harmony (think 670) I was going to try to use
CPU Cooler: thinking using stock
post #5 of 6
What's the microcenter deal? I'm looking to start an HTPC build and am curious...
post #6 of 6
In store only, purchase i5 (I don't know if other models available) and get $40 off mobo. Price on 3570k was good too. Microcenter seems to lower 3570k down to $160 occasionally.
