AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › OPTOMA HD91 FULL LED DLP full hd 2D 3D Ready end 2013
OPTOMA HD91 FULL LED DLP full hd 2D 3D Ready end 2013 - Page 16
post #451 of 1158
Originally Posted by biliam1982 View Post
I thought I read this LED Optoma would be using a different type of DI and not a mechanical one so maybe it'll be better.
Actually dimming the LED's doesn't improve CR like closing a physical lens iris.
post #452 of 1158
Yes they amplify brighter parts in the image and mess with the gamma too.
post #453 of 1158
Originally Posted by HTCrazy View Post
OTOH my LG $400 PA70G LED PJ has had zero loss in the first year. How many bulb projectors can you say that about.
During some research into LED's, I read they will increase in brightness initially before they start dimming.
Did you take multiple reading over the year to track it?
post #454 of 1158
Originally Posted by hifiaudio2 View Post
Well I attempted to register and ask a question on this thread:
http://www.myav.com.tw/bbs/showthread.php?s=&threadid=20462879
But as far as I can tell there has been no answer. There is an Optoma representative that posts in that thread, so I was hoping to get some clarification around the brightness measurement.
Hi,
it seems you have an answer...
http://translate.googleusercontent.com/translate_c?depth=1&rurl=translate.google.com&sl=zh-CN&tl=en&u=http://www.myav.com.tw/bbs/showthread.php%3Fs%3D774c8f11ef7fd8af87a90ec9368aec72%26threadid%3D20463106%26pagenumber%3D4&usg=ALkJrhhp5XIz5PhBaC0UUYTVNqcpNfnLKA
with those figures, it's 540 lumens at D65. Not bad (in 2D)
post #455 of 1158
Hifiaudio2 can rule this one out. No way 540 lumens is enough to light up his 160" wide screen. Not enough in 2D, much less 3D.
post #456 of 1158
Yep - out for me. Really too bad.
post #457 of 1158
Is there a real world calibrated measurement of the Cine 1000 somewhere? So its 1000 lumens are true?
I haven't seen one. But I did see it light up a 165" diagonal StudioTek 130 screen at CEDIA. It had no problem doing that.
post #458 of 1158
Hi,
maybe the "Helmholtz-Kohlrausch" effect wink.gif :
http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=fr&ie=UTF-8&u=http%3A%2F%2Fwww.prad.de%2Fnew%2Fnews%2Fshownews_beamer7227.html
http://en.wikipedia.org/wiki/Helmholtz%E2%80%93Kohlrausch_effect
post #459 of 1158
post #460 of 1158
That could be true - it DOES seem brighter than it was initially. It's been about a year so far with maybe 600 hours which would have already lost significant brightness with my former bulb projectors. Hard to imagine it losing that much brightness but time will tell.
post #461 of 1158
I must say I am still very excited to learn more about this projector as more reviews appear. I am very happy with my 92" screen and I know there are many, many AVSer's who enjoy 92-106" screens... which would result in a better ft-L figure.
post #462 of 1158
At that screen size this would be the top of my (interested in) list.
post #463 of 1158
I'm still excited too, and it would be OK for my current screen, a Da-Lite HCHP 116" wide scope. But I would like to go larger in size one day without having to pay close to $10k for a projector that can do it.
How big is your screen?
post #464 of 1158
160" wide AT.
post #465 of 1158
He is going to need a 4K LED projector after owning the 1000ES
post #466 of 1158
Looks like my only real option is to get the 1000es again.
post #467 of 1158
160" wide AT.
post #468 of 1158
160" wide AT.
I calculate about 7-8 ftl's but if you figure in Runco's claim of 60% perceived brighter image for LED's, you'd have about 12 ftl's.
Def not enough for 3D but close enough for 2D.
post #469 of 1158
60%? Lol I haven't seen the effect called that much! I had the led/ laser Panasonic hybrid in my theater for a day. I measured around 600 lumens. It was dim and horrible. Maybe the LED effect wasn't in force because of the laser part.
post #470 of 1158
I'm getting around 12ftL and it seems comparable to 15-16ftL with my LED projector
post #471 of 1158
Originally Posted by Seegs108 View Post
let alone to take apart a projector, wire it properly and then put it back together with the hopes they did everything correct.
My LCD panels went bad on my Panny 700 after 5 years. Bought a dead PJ for like $100 and rebuilt mine... stripped it down to the frame, and cleaned every bit (including disassembling the lens and polishing every element).
I hadn't intended to go as far as I did (ie, lens), but just kept going - photographing everything along the way to ensure I put it all back. Worked like new for 3 more years. Replacement panels are going bad, time to throw it out and get a new PJ. But I agree - not something many people would be crazy enough to try.
post #472 of 1158
So no one in the USA has one yet? Can it be bought from where its available and shipped here?
post #473 of 1158
That is because 12 ftl always seem comparable to 15-16 ftl.
post #474 of 1158
Not to me
post #475 of 1158
Hi
HD91 specifications are available on Optoma Europe Web site with a distance calculator :
http://www.optomaeurope.com/projectordetailshc.aspx?ShowMenu=HC&PTypedb=High%20Definition%20Home%20Cinema&PC=HD91
There are one point on the "Helmholtz-Kohlrausch" effect.
http://www.optomaeurope.com/distancecalc.aspx?PC=HD91
Remember, the HD91 is the "long throw" model.
post #476 of 1158
post #477 of 1158
Originally Posted by Thebes View Post
Hi
Hi,
there are also :
User Manual :
http://www.optomaeurope.com/uploads/manuals/HD91-M-en.pdf
Quick Start Guide :
http://www.optomaeurope.com/uploads/quickstarts/HD91-QS--.pdf
Brochure :
http://www.optomaeurope.com/uploads/brochures/HD91-B-en.pdf
post #478 of 1158
It is not possible to judge such subtle differences by remembering it.
post #479 of 1158
I always set two settings on my jvc projectors with one between 10-12ftL for darker movies to maximize contrast and the other 16-18ftL for action movies with not so many dark scenes. My action movies always seemed too dim at 12ftL. I don't get that dull feeling now. But I will be trying to get another jvc soon to compare it with the DP
post #480 of 1158
I looks like more info is being posted and that is encouraging that maybe a release in the US might be sooner rather than later. It looks like it might be available in the UK.
http://www.optoma.co.uk/projectordetailshc.aspx?PTypeDB=High%20Definition%20Home%20Cinema&PC=HD91
