Originally Posted by stanger89
In the $20k+ forum, Wolfgang posted pictures of a Sim2 Lumis next to a JVC RS20, side by side in the same room with the peak white levels equalized. The results there are rather interesting given he measured the RS20 at 26000:1 on/off contrast and the Lumis at only 18000:1.
Great article on contrast, but as far as the Wolfgang thing though:
Well, the main problem with his test is that 18,000:1 and 26,000:1, only about a 45% increase in native contrast isn't very much to the eyes when we are already above 15,000:1. So if you have a high enough spread of ANSI and native on/off that close, then yah we can see some better blacks when there is that much light in the room (because the two projector's are polluting each other's light source in his PJ A on / PJ B on testing method. With light pollution from both projectors the on/off advantage will be lessened, so that test isn't really the best one. The projectors need to be compared by taking a spot measurment with an accurate light meter in A then B, not A+B at the same time.
All this said, I am not saying we cannot see ANSI contrast between a DLP and a JVC, I am adamant that we can, but I'm just saying that after that, like on a Sony vs. most DLP's, you're not going to see it much according to my tests. The JVC is really the only projector to worry about lower ANSI on, and even then it still doesn't affect all that much scenes in movies, more so in documentaries and day-light stuff.
Edited by coderguy - 2/4/13 at 10:30am
