Complete newbie to calibrating a TV. I don't have any equipment just an interest in doing it for myself, family and friends. Where do I start? I would be willing to drop a grand on getting set up but don't even know what matters and the whole thing is overwehlming. Any ideas on where to start, what to read, what matters, etc would be great.
Featured Stories
Where to start?
AVS Top Picks
post #2 of 25
1/29/13 at 2:49pm
- sotti
- Trader Feedback: 0
- offline
- 6,090 Posts. Joined 8/2004
- Thumbs Up: 61
- Select All Posts By This User
I'd start off just doing the basics.
Get a disc like spears and munsil or DVE. Try to follow through doing a manual calibration, with just optical patterns.
Getting the hang of just setting brightness, contrast, color and tint is a big start on what calibration is about, and the entry cost is pretty low.
If you still want to proceed after that, then you'll want to get your hands on some kind of color analyzer and software.
There are free options for software and there are pay options. The pay options have much more flexibility and will do a much better job of walking you through what you need to be doing. I'm personally quite fond of CalMAN, but that's likely just because I'm in charge of developing it for SpectraCal.
post #3 of 25
1/29/13 at 2:53pm
- Michael TLV
- THX-ISF'er at Large
- offline
- 6,423 Posts. Joined 2/2000
- Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
- Thumbs Up: 17
Greetings
Options
1. DIY ... go buy the software and the hardware and look for articles that teach you how to do this.
2. Hire a professional to calibrate your display and make sure he is one that also educates. He can teach a lot in the 4-5 hours he is there. He won't do your friends and family though.
3. Third option is to buy the DIY'er gear and software ... Save the 100's of hours of research time by getting real video calibration training (not free)
Cost of DIYer path is $400 or so with the two pay software options. But you can do other TVs in your house too and friends and family and retweak as much as you want. (Albeit with less accurate gear)
A pro calibration of the set will run $400 to $550 depending on what you ask them to do. But they do it with way better gear and experience has to be worth something.
What is the cost of your time worth?
Is the goal to have a calibrated TV sooner rather than a lot later?
Is the end goal to have a calibrated TV or actually to learn the entire process of calibration?
regards
Options
regards
- marcojames
- offline
- 12 Posts. Joined 1/2013
- Thumbs Up: 11
post #5 of 25
1/30/13 at 12:02pm
- sotti
- offline
- Thumbs Up: 61
That's a question you'll have to answer for yourself. The best gear in the hands of an amateur (by knowledge, not profession) won't get you a good calibration, but the most well versed professional would struggle if given substandard equipment.
So you'll need both knowledge and good equipment to get the best results. To get the knowledge, paid training is absolutely the fastest method, but if you are good at self education there are plentiful free resources, but finding the correct resources and educating yourself can be very time consuming.
Luckily these days, equipment is getting better so even entry level stuff should give good results.
Edited by sotti - 1/30/13 at 12:10pm
post #6 of 25
1/30/13 at 12:16pm
- Michael TLV
- offline
- Thumbs Up: 17
Greetings
Considering that Video Calibration Training Videos will cost you all of $150 ... and you can watch them as many times as you want until it sinks in ... (The cost of quality training is not the most expensive thing in this hobby)
It's back to the cost of your time .... versus money.
A Color Munki is $400 ... and add software to that ... gets you to the $600 price point ...
How do you define great gear? My Jeti costs $12000 ... that's "great" gear ... only from a certain point of view. (Not so great compared to a $40000 Minolta CS2000) My i1pro costs $1000 ... most professional calibrators use that ... which is great compared to stuff that costs less ... maybe. A Color Munki Photo at $400 has similar performance to the i1pro ... in the right hands.
Regards
Regards
post #7 of 25
1/30/13 at 1:29pm
- turbe
- Trader Feedback: +1
- Quantum Entanglement
- offline
- 4,129 Posts. Joined 2/2001
- Thumbs Up: 31
time time time must be put in...
As far as meters, I always recommend a i1Pro Spectrometer, even a used i1Pro Rev D ($250-$450) is great, ColorMunki Spectro (as mentioned above) is my 2nd choice
Why a Spectro, see why here:
http://www.avsforum.com/t/1373556/i1-pro-or-d3-if-you-could-only-have-one-meter
http://www.tlvexp.ca/2012/04/do-calibration-tables-really-work-for-tri-stim-devices/
And Read this Thread:
http://www.avsforum.com/t/1449310/eye-one-pro-or-display-3-pro
I would start/stick to using discs for your patterns (AVS HD 709, GCD others here on this forum) with your player to start with.. I think it's important to learn which patterns you need when.. down the road, you can save up and add something like the iScan Duo which can be used as a pattern generator or an Accupel 5000 (or maybe even pick up a used Accupel previous generation) if you want to automate your patterns.
If you want to jump start it, take Michael's advice above about the online video training that he has produced/made available.. but... don't make the mistake and think your learning stops there..it's never ending.
are you quoting a retail price or why did you pay that much, the 1211 can be had for less than that last time I checked by a few thousand $$
Edited by turbe - 1/30/13 at 1:44pm
post #8 of 25
1/30/13 at 2:17pm
- Michael TLV
- offline
- Thumbs Up: 17
- marcojames
- offline
- Thumbs Up: 11
Thanks for the time guys, I know it is really basic.
Sotti, I have used discs like that before, but I am hoping there is more science to it than "my eyes say this looks right", mainly because I don't trust my judgement.
I will take a closer look at all the links provided, thanks. I am guessing the i1 Pro vs Munki preferences discussed above come down to a colorimeter vs spectrometer debate?
post #10 of 25
1/30/13 at 2:58pm
- sotti
- offline
- Thumbs Up: 61
Books, and books, and books of science.
The "art" part of calibration is only due to limited controls and the subjective nature of compromise.
With enough control all the targets can be calculated and the colors quantified, adjusted and validated.
Edited by sotti - 1/30/13 at 3:21pm
post #11 of 25
1/30/13 at 3:08pm
- turbe
- offline
- Thumbs Up: 31
No.. both are Spectros (though there is a ColorMunki colorimeter model, stay away from that one).. my reference to the ColorMunki is the for the Spectro models
my first recommendation is a i1Pro Rev D. (even used) or i1Pro2 (replaced the i1Pro Rev D.) - Spectro
my second recommendation is the ColorMunki Spectro (i.e. ColorMunki Photo) - Spectro
If I had a choice between a used i1Pro Rev D. for $400 (they sell for $250-$450) or a new ColorMunki Spectro $400 - I'd go for the i1Pro Rev D.
Between the two, the ColorMunki Spectro can be awkward for mounting but doable... (Rayjr designed a tripod mount for it as well). Not a big deal if you are profiling a colorimeter to it.
Check out this thread about the ColorMunki: http://www.avsforum.com/t/1215746/colormunki-how-good-or-how-bad/60#post_18023662
the i1Pros are still used by many Professional Calibrators.
Please do check out those links in post #7 above..
Edited by turbe - 1/30/13 at 3:19pm
- marcojames
- offline
- Thumbs Up: 11
Well let's see if i have this right...
Big preferences out there for a Spectro over a colorimeter. Mostly due to accuracy and accuracy over time as filters degrade.
Spectros available in the consumer realm the iPro 2 and Color Munki (new), possibly a used iPro Rev D as well. The knock on the color munki is using it for TV calibration can be clunky as it wasnt designed for it. The IPro seems to have strong support.
Lots or arguments for the iD3 (a colorimter?) in conjunction with the iPro.
One thing I don't know is the know on the spectro's. Is it lack of accuracy at low light levels or just slow readings? Slow doesn't bother me.
post #13 of 25
2/2/13 at 8:58am
- turbe
- offline
- Thumbs Up: 31
In general, colorimeters can have better low light sensitivity and can report faster..
Even with a Photo Research PR-670, I know a Calibrator that doesn't trust the results much lower than 20%, he uses other tools down low
save me some key strokes:
Are we perfect?
Originally Posted by Michael TLV
Greetings
We tend to trust the i1pro down to about 20% ... but not lower. Human eyes then come in to compensate for the weakness of the probe in that area.
We can see red and green errors faster than the probes can at low light conditions. And we are forgiving on blue errors ... just harder to see.
Worrying about errors that are beyond human perception is kind of a waste of time. No instrument is perfect. When an imperfect instrument tells you that you are perfect ... are you? If you think you are ... then there is another problem.
Regards
Greetings
Regards
Are we perfect?
- marcojames
- offline
- Thumbs Up: 11
I just don't trust my eyes yet so unerstanding what I need to learn to evaluate is part of this whole thing. The calibrater who doesn't use his PR-670 at low levels uses "other" tools. Did you mean his eyes? Do you mean a colorimeter that has been profiled to the PR-670, his eyes, something else entirely?
post #15 of 25
2/2/13 at 4:18pm
- turbe
- offline
- Thumbs Up: 31
post #16 of 25
2/2/13 at 5:01pm
- Chad B
- ISF/THX Touring Cal
- offline
- 1,732 Posts. Joined 10/2002
- Thumbs Up: 67
- marcojames
- offline
- Thumbs Up: 11
Thanks for the continued input, and sorry if my question was out of line, it wasnt meant that way.
How about this article?
http://www.curtpalme.com/docs/XriteDisplayCalibrationDevices.pdf
This says to me that I should at most be considering a D3 Pro? Maybe add a spectra like the iPro 2 later, that way if I do keep doing this I have both meters and I can use the iPro to update the tables for the colorimeter. I wouldn't see myself ever needing/wanting to spend thousands on meters so the combination of the two would be the most I could ever see myself buying. It seems like good entry plan to me, what do you guys think?
post #18 of 25
2/4/13 at 9:46am
- sotti
- offline
- Thumbs Up: 61
That is good balance between cost and accuracy. Getting a spectro first would be more expensive, but more accurate, if you were only going to have 1 meter and you needed it to be as accurate as possible than an i1Pro would be the better choice.
But the 2 meter combo with profiling is great perfomance and value compared to how much you'd spend on a meter that could outperform the pair.
And if absolute accuracy isn't your #1 priority (say cost is #1), then starting with a i1D3 is a very good choice.
post #19 of 25
2/4/13 at 10:31am
- Michael TLV
- offline
- Thumbs Up: 17
post #20 of 25
2/4/13 at 10:41am
- sillysally
- Trader Feedback: +2
- offline
- 3,068 Posts. Joined 6/2006
- Thumbs Up: 24
When I started out calibration,with Calman 3, I found the step by set, how to and what everything means to be helpful and at the same time it was hands on. Of-course Calman has come a long way and now offers a very good Calman 5.1 Beta autocal (at least with the 3D LUT Cube work flow) there is not much point in buying a how to disc.
Save your money get Calman 5 (at-least Control) a used I1Pro D version and a i1 Display Pro (OEM).
For those that want the best Get a Lumagen Mini 3D and Calman 5 Enthusiast, use the auto 3D LUT Cube workflow (125 point Gamut, 21 point Gamma/Grayscale). This type of calibration no pro calibrator will be able to beat or come close to, doing a normal ISF calibration (6 point Gamut, 10 point Gamma/Grayscale.
btw, Calman is not the only game in town, but its the only one I have experience with.
ss
Edited by sillysally - 2/4/13 at 10:47am
ss
post #21 of 25
2/4/13 at 10:59am
- sotti
- offline
- Thumbs Up: 61
Well the C3 has exposed filters versus the i1D3 with it's sealed optics. So the durability of the i1D3 is going to be a bit better, it also has a diffuser, optics and a tripod mount which makes it usable for projectors where the C3 isn't designed for reading projection display.
That said it is a great meter for the money.
post #22 of 25
2/5/13 at 6:19am
- nick-t
- offline
- 40 Posts. Joined 1/2013
- Thumbs Up: 13
all the guys over in my owners thread are talking about how they are adjusting their settings to make the tv look better. lots of pop and punch being talked about, but I really don't know where to start. this thread caught my eye because I need to know where to start.
Sotti, what are the options on discs? Anything other than the spears and nmunsil? Any pros or ocons of different discs?
post #23 of 25
2/5/13 at 7:58am
- turbe
- offline
- Thumbs Up: 31
I think for absolute noobs, try the Disney WOW.. you may be able to rent DVE on netflix
You can try this AVS HD 709 (free,, just burn to a DVD) it has the patterns to do the very basics without an meter and if you add one in the future, you will be able to use that disc for calibration.
AVS HD 709 download , info and manual here: http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration
I would hold of on Spears and Munsil, their new Edition is coming out in a couple months, may be good for beginning and advance
post #24 of 25
2/5/13 at 8:47am
- realzven
- offline
- 316 Posts. Joined 3/2010
- Thumbs Up: 19
Any news on the new edition of S&M ? thanks turbe
post #25 of 25
2/8/13 at 3:24am
- ThePrisoner
- offline
- 2,067 Posts. Joined 1/2004
- Thumbs Up: 11
- Where to start?
AVS Top Picks
Currently, there are 1058 Active Users
(150 Members and 908 Guests)
Recent Discussions
- › Main Lobby Controller Question 1 minute ago
- › 2013 Formula 1 in HD 2 minutes ago
- › Apple TV owners' thread. 2 minutes ago
- › Official ZT60 Owners Thread 3 minutes ago
- › How power law gamma calibration can lead to crushed blacks 3 minutes ago
- › Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide 9 minutes ago
- › Oculus Rift VR Headsets 9 minutes ago
- › Home theater/Video game/HTPC/2 Channel rig (Mitsubishi,... 10 minutes ago
- › The **OFFICIAL** DENON AVR-4520CI thread 10 minutes ago
- › *Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread 10 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
View: More Reviews
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
