AVS › AVS Forum › Audio › Speakers › Wall mounting my Energy Veritas V-Mini Center - Help Please!!!
post #1 of 10
Hi guys,
I'm struggling with mounting my Energy Veritas V-Mini Center channel speaker. Given my set up, wall mounting is the only option.
Both bookshelf mini`s came with a mount so no issues there. I e-mailed OmniMount and they`re asking what the thread size on the back is. Can anyone tell me or provide options.. Thank you!!
post #2 of 10
What about a stand?
post #3 of 10
Originally Posted by OilCountry82 View Post
Hi guys,
I'm in the same situation, what did you wind up doing?
post #4 of 10
its the same thread pattern as your other V mini bookshelf speakers.
Take the screw out of the back of the speaker and you'll know the size and pattern.
Easiest way to wall mount the center is to just build a small shelf or use two brackets like this.
http://www.amazon.com/Pinpoint-Center-Channel-Speaker-Mount/dp/B002MP5JX4/ref=pd_cp_e_0
post #5 of 10
I'm not sure that is stable enough if mounting vertically, near a busy door.
post #6 of 10
Oh you're trying to mount the center vertically?
post #7 of 10
yes alongside the tv. Otherwise the bracket you linked would have done the trick.
post #8 of 10
Wondering if you found a good solution for mounting VMINI CC vertically? Would a pair of brackets that comes with VMINIs work for the CC if they are bought seperately.
Trying to help a friend who is in a similar situation to yours. He wants to mount CC vertically for L/R position.
post #9 of 10
Anyone able to confirm the thread size on the v-mini bookshelf? Included brackets aren't going to work. Need to get ceiling mounts and want to get the right ones.
post #10 of 10
Anyone figure this out? I am hoping to figure out a way to mount my V-mini bookshelves and center to my wall mount (VideoSecu MW380B) for my Panasonic TC-P55GT50, which I think has VESA 500X300.
Curious about this Monoprice for the L/ R speakers:
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082804&p_id=9900&seq=1&format=2
May try to retrofit some universal soundbar mounts for the Center:
http://www.amazon.com/Bentley-Mounts-Universal-Soundbar-Bracket-black/dp/B00873FGP6/ref=sr_1_6?s=electronics&ie=UTF8&qid=1380585159&sr=1-6&keywords=soundbar+mount
I have to say it has been a hateful task trying to figure out how to align all of these TV/VESA/Mount/Weight/Articulation/SupplementalMountingBrackets/SpeakerMountConnections/etc/etc.....
  Back to Forum: Speakers
