I just wanted to contribute...It may be a little late since this PJ is a little old (only a couple years for me) but none the less Im doing a remote revamp and I made a spreadsheet of all the SET codes for the VW60.
WARNING!!! this is a Macro enabled Spreadsheet their is a VBA module to calculate the checksum. Just incase you want to use them as GET commands or change them based on PJ model. Just wanted to let you know!
Looks like they will work with some other Sony PJs as well.
VPLVW60RS232.zip 87k .zip file
Edited by coffeeguy57 - 1/31/13 at 6:38pm
