AVS › AVS Forum › A/V Control & Automation › Remote Control Area › URC RF20 question
URC RF20 question
post #1 of 2
I have easily set up and programmed my RF20. Only problem so far is how to get the channel selector to change via the cable box and the volume to control the Onkyo receiver without having to change devices. I can't seem to program the toggle switches via a macro. Any suggestions? Thanks.
post #2 of 2
Go into the menu of the RF20 , select Punch Through, chose volume, pick the device the volume is coming from, then the device you wish to punch the volume to.
  Back to Forum: Remote Control Area
