post #1 of 1
Woot has always delivered some great deals to my household, this one looks good too for an HTIB.
http://www.woot.com/?variation=1&utm_expid=31924516-10
System:
Total Power: 1030W (7.1 System)
Power: 130W per channel (6Ω, 1kHz, 1%, 1 Channel Driven, FTC)
Subwoofer Output: 120W
Audio Processing: Dolby Decoder: TrueHD, DD Plus
DTS Decoder: DTS-HD Master Audio, HD-High Resolution Audio, NEO:6
Dolby PLIIz and Audyssey DSX™
Onkyo Game Surround Modes
Audyssey Dynamic EQ: (2EQ)
Audyssey Dynamic Volume
Music Optimizer: Advanced
Internet Radio Services vTuner, Spotify, SIRIUS XM Internet Radio®, Pandora®, Slacker™, Napster, Rhapsody® and AUPEO!
Inputs: (6) HDMI v1.4a with 3D video & ARC support (1 front)
(2) Digital Audio (optical)
(2) Digital Audio (coaxial)
(6) Analog Audio
(5) Composite (1 front)
(2) Component Video
(1) PC-in
(1) RJ-45
(1) USB (front)
(1) FM Antenna
(1) AM Antenna
Outputs: (1) HDMI
(1) Analog Audio
(2) Composite
(1) Component Video
(7) Binding Post Binding Terminals (L/R)
(1) Powered Zone2
(1) Zone 2 Line-out
(2) Subwoofer Pre-out
(1) Headphones (front)
Other Ports: (1) Universal Port
(1) RI Remote Control
(1) Setup Mic (front)
Video Input Conversion: Analog to HDMI Upconversion
Video:
Input Sensitivity: 1.0 Vp-p/75Ω (Component)
0.7 Vp-p/75Ω (Component PB/CB, PR/CR)
0.28 Vp-p/75Ω (S-Video C, PR/CR)
1.0 Vp-p/75Ω (Composite)
Frequency Response: 5Hz - 100MHz (-3 dB)
Tuner:
Frequency Range: FM: 87.5MHz - 107.9MHz
AM: 530kHz - 1710kHz
FM/AM Preset Memory: 40 Stations
Speakers:
Speakers: Front: 2-Way Bass Reflex
Center: 2-Way Bass Reflex
Surround: Full-Range, Acoustic Suspension
Surround Back: Full-Range, Acoustic Suspension
Subwoofer: Bass Reflex, Powered
Drivers: Front: (2) 3.25" Cone Woofer, 1" Balanced Dome Tweeter
Center: (2) 3.25" Cone Woofer, 1" Balanced Dome Tweeter
Surround: 3.25" Cone
Surround Back: 3.25" Cone
Subwoofer: 10" Cone
Frequency Response: Front/Center: 55Hz - 50kHz
Surround: 80Hz - 20kHz
Surround Back: 80Hz - 20kHz
Subwoofer: 25Hz - 150Hz
Output SPL: Front: 79.5 dB/W/m
Center: 79 dB/W/m
Surround: 81 dB/W/m
Surround Back: 81 dB/W/m
Subwoofer: N/A
Max Input Power: Front/Center/Surround: 130W
Surround Back: 130W
Impedance: Front/Center/Surround: 6Ω
Surround Back: 6Ω
Subwoofer: 550mV/20 kΩ
Dimensions: Front: 10.3"(W) x 41.1"(H) x 10.3"(D)
Center: 16.6"(W) x 4.5"(H) x 4.8"(D)
Surround: 4.5"(W) x 9.1"(H) x 3.8"(D)
Surround Back: 4.5"(W) x 9.1"(H x 3.8"(D)
Subwoofer: 10.8"(W) x 19.9"(H) x 16.2"(D)
Weight: Front: 11.5 lbs
Center: 4.9 lbs
Surround: 2.2 lbs
Surround Back: 2.2 lbs
Subwoofer: 25.6 lbs
Amplifier:
Channels: 7.2
Power Output: Front L/R: 130W per channel (6Ω, 1kHz, 1%, 1 Channel Driven, FTC)
Center: 130W (6Ω, 1kHz, 1%, 1 Channel Driven, FTC)
Surround L/R: 130W per channel (6Ω, 1kHz, 1%, 1 Channel Driven, FTC)
Surround Back L/R: 130W per channel (6Ω, 1kHz, 1%, 1 Channel Driven, FTC)
Dynamic Power (front): 180W (3Ω)
160W (4Ω)
100W (8Ω)
THD+N: 0.08% (20Hz - 20kHz, Half Power)
Damping Factor: 60 (Front, 1kHz, 8Ω)
Input Sensitivity: 200 mV/47 kΩ (Line)
Impedance: 200 mV/470Ω (Rec out)
Maximum Source Impedance: 2.0 V/2.2 kΩ (Rec out)
Frequency Response: 5Hz - 100kHz/ +1 dB, -3 dB (Direct Mode)
Tone Control: ±10 dB, 50Hz (Bass)
±10 dB, 20kHz (Treble)
Signal to Noise Ratio: 106 dB (Line, IHF-A)
Speaker Impedance: 6 - 16Ω
THX Certified: Select2 Plus
Power Supply: AC 120 V, 60Hz
Power Consumption: 4.9A
Standby: 0.2W
Dimensions: 17.1"(W) x 6.8"(H) x 12.9"(D)
Weight: 24.7
In the box:
Onkyo TX-NR609 THX Select2 Plus 7.2-Channel Receiver
(2) Two-Way Tall-Boy Speakers
(2) Surround Speakers
(2) Surround Back Speakers
Center Speaker
Subwoofer
FM Antenna
AM Loop Antenna
Color Coded Speaker Cable
Subwoofer Cable
Speaker Set-up Microphone
Remote Control
Manual
