Ok, so ive just finished my first (hopefully last for a while) HTPC build.
Ok so i want the [*] Ceton InfiniTV 4 Quad-tuner Card for Watching Digital Cable TV on the PC, PCI-Express x1 Interface but needed something till i saved for the that, and picked up a Hauppauge WinTV-HVR-2250 ( i needed the WMC remote and ir gear and it was on the shelf at Tigerdirect... probably not the best way, but non the less)
Ok my question is, i have my cable box (premium HD content) feeding the WinTV-HVR-2250 via coax... but i cant seem to see any HD in WMC. I think i understand that i cant record HD but I should still be able to see it right? i can see my premium channels (the feed just comes straight out of the cable box.. ) but something is stripping the HD out of it....
thoughts?
- SILVERSTONEGrandia Series SST-GD05B-USB3.0
- ASRock Z77 Extreme4-M LGA 1155 Intel Z77 HDMI
- Seasonic SS-560KM Active PFC F3, 560W ATX12V V2.3/EPS 12V V2.91, 80Plus Gold Certified, Modular Power Supply
- Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
- SAMSUNG 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model MV-3V4G3/US
- SAMSUNG 840 Series MZ-7TD120BW 2.5" 120GB SATA III Internal Solid State Drive (SSD) (For the OS)
- Western Digital WD Green WD20EZRX 2TB IntelliPower SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive (RAID0)
thoughts?
