Hoping not to offend anyone's sensibilities here, but...
I have several (currently 4, soon to be 6) zones of audio in the house (speakers installed during build - local volume controls in-line - wiring home run to equip closet). I am running these with 3 Pyle PCA1 amps (15x2 watts) fed from a Verizon Fios STB. The amps have hard power switches, so the control is via Insteon ApplianceLinc modules. I know this setup is a little hokey, but we really only use it for background music, and it sounds suprisingly ok - and all for a very manageable budget. We always use the same source for all zones - just don't always need them all on.
I have the input split 3 ways via stacked Y-cables - so far, so good. Now that I want to add more zones, I will need to split the signal further. Keeping in mind the LOW budget I'm dealing with, how many times can I reasonably split the signal?
Can I go to 5 (or better yet 6) amps? Do I need an audio splitter/amp? Is there one out there that is not meant for "broadcast professionals" (i.e. CHEAP)? If I use a composite/audio A/V splitter/amp - will it balk with no video connected?
BTW - Pyle does not list the input impedence on the amps, but what do you expect for ~$20....
I don't claim to be an expert, but the ears don't lie.
