Originally Posted by
WagBoss
bi-amping doesn't do anything. your receiver is limited by the power supply, not by the channel output. technically the way receivers do it is called bi-wiring. bi-amping does do something, but you need 2 amps
actualy, because the tweeter only gets maybe 25 percent of the power anyway, biamping can't increase available power enough to make more than a decibel of difference. And if you're not clipping, you won't hear a difference between biamped and non biamped. That said, I biamped my Sonus Fabers and my Magnepans and everything worked dandy.
