AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Accessing Denon1912 from wired and wireless devices
post #1 of 4
I have a Denon 1912 that is connected to my network using power line adapters. It works fine, I can stream music, etc. The airplay works when I use my computer that is on the network through a wired connection. However, it does not work when I use wireless devices (iPhone, Laptop). Also, the iPhone Denon Remote App cannot detect the receiver. Any help will be greatly appreciated.
post #2 of 4
post #3 of 4
I cannot see a solution to my problem in your link.
post #4 of 4
Did you look only or did you try them as they will generally resolve the issue you're having with the Airplay icon not showing up on the phone or PC.
