So I just bought a foreclosure that is pre-wired for speakers. There arent any speakers in the walls or ceilings. There are mounts for the speakers along with jacks to plug in banana plugs. Also, there is a surround sound connection wall plate in the master bedroom and a lot of loose wires in the basement where i figure everything is supposed to connect to. I need help as to what i need to get this up and running and what do i do with all the wires in the basement. Thanks for your help!!
AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Bought a house thats pre-wired...need help!!!!
AVS Top Picks
post #2 of 10
1/30/13 at 10:11pm
post #3 of 10
1/31/13 at 1:59am
post #5 of 10
1/31/13 at 9:20am
post #6 of 10
1/31/13 at 9:24am
post #8 of 10
1/31/13 at 11:23am
post #10 of 10
1/31/13 at 9:17pm
AVS Top Picks
