AVS › AVS Forum › Video Components › Home Theater Computers › New Hard Drive won't initialize.... "the device is not ready"
post #1 of 6
i have a new WD 2TB hard drive that I'm putting into a MediaSonic USB3.0 external enclosure. After attaching the hard drive, I went into Computer Management to initialize the disk. When I tried to do that, I get an error that pops up from the Virtual Disk Manager that says, "The device is not ready".
I've tried detaching and re-attaching the drive and rebooting my HTPC, but no luck.... Any ideas? Do I have to initialize it with a SATA cable on the motherboard first before putting it in the enclosure?
post #2 of 6
Don;t think so, but doing this would immediately reveal whether the drive itself is fault. If it won;t work properly connected directly to a SATA port either, then it;s the drive. If it does work properly, the problem is elsewhere.
post #3 of 6
And it's not your enclosure? You said USB 3.0 -- is there USB 3.0 on your mobo? Got the drivers loaded to support the USB 3.0 port? Proper USB 3.0 cable? Try hooking the enclosure to a USB 2.0 port as a test... maybe even reuse a known good USB 2.0 cable on that one.
post #4 of 6
I attached the hard drive to my motherboard and it initialized fine. And then I put it back into the enclosure and everything was ok. Not sure what the deal was last night....
Yes, I do have USB3.0 on my mobo and I'm using the cable that came with the enclosure.
post #5 of 6
Glad you got it working! Tell us how your transfer speeds are using the USB 3.0 interface, please.
post #6 of 6
I tried a couple of transfers.... when transferring mp3s and photos I was getting around 50 MBps. when transferring home movies (Canon .m2ts files), I was getting around 68 MBps.
I haven't tried updating drivers or anything... I did see a bunch of sticky posts on the MediaSonic forums about updating drivers.
