I need lots of advice. Here is the long setup:. I have very limited funds right now but am trying to fix up my old analog sustem. First step is probably to replace my ancient Sony CD player with a dedicated laptop that can hold all my CDs in a lossless format(Itunes). My regular laptop in in another room and is not always on so need dedicated one for stereo. Thought about Ipod classic but then have to buy a digital dock and a DAC. I don't currently download music, but envision doing so as more becomes available at higher resolution.
My stereo setup, also ancient, consists of Adcom GTP400 tuner/pre-amp, Adcom GFA-535 amp, Monitor Audio Silver 3i speakers. All were purchased in late 80s/early 90s. Mock if you must but it has met my needs very well. I play a mix of classic rock, acoustic folk, jazz, classical and generally at moderate sound levels. Think everything from John Hyatt to Delbert MClinton to Clapton to Jean-Luc Ponty To Bach. If I understand the info I've picked up, the speakers may be a bit weak in bass [45Hz-25Khz, sensitivity 88dB, 8 Ohms, 80 watts, front ported, 5.5" C-Cam mid-bass driver, 1" gold tweeter. ]The amp is listed at 60 watts but reviews at the time said it is more like 80 watts.
Obviously, the primary problem is to get digital signals to analog setup.My first idea was just to add a DAC. Based on reading all over the web, I was leaning toward a Micromega Mydac or a Peachtree Dacit. Currently only need to hook up the computer, but may want to add tv or dvd player at a later date. There is nowhere local to listen. Then I started to think that maybe an even cheaper Dac plus subwoofer might make more sense. Have no idea what to look for or how to hook that to the old Adcom which doesn't have output specifically for a subwoofer.
Elsewhere on this site someone suggested that an Apple Airport Express with better speakers would be a better choice than a basic freestanding DAC. I am now completely confused. I actually think my speakers sound pretty good and they are a good size and quite lovely.
I currently have about $550 ($675 if don't need the laptop) to spend and that has to include any fancy cables or upgraded power supplies. I am willing to buy used but am leery of buying from private sellers on Ebay.
Apologies for the long message and any advice greatly appreciated.
