Hi all.
I am getting ready to move am older Sharp Aquos 48" LCD into a corner. I prefer to keep it mounted to a wall. I saw the Peerless CM series and they mention the requirement of a peerless flat mount to go with it.
Currently my TV is mounted with a cheap monoprice mount. Does anyone know if that would be compatible with the peerless system? I'd like to keep the cost down, and the corner mount is bad enough by itself.
I am not looking for an articulating arm as I am concerned about sag over time, and I plan on having it fixed viewing from the corner.
If any other systems exist out there that people are aware of, if you wouldn't mind sharing that., I'd appreciate it as well.
Thanks in advance.
-Chris
Thanks in advance.
-Chris
