Emotiva Pro largest and most powerful speaker is the new Stealth 8 monitor. Designated as a near field monitor, the Stealth 8 is packed with audiophile-friendly features and plenty of power. The highlight of this 400-watt bi-amplified speaker is the airmotiv™ tweeter, powered by its own 200 watt amp. The use of folded diaphragm tweeters is gaining in popularity, chosen for their near-perfect transient response. The Stealth 8 pairs such a tweeter with an 8" woofer to provide 115db of output at 1 watt/meter. Both drivers are mounted to a 2" thick extruded baffle, helping to minimize diffraction and giving the monitor a very serious industrial look.
At $750 a piece the Stealths are not exactly bargain speakers, however with so much power for each unit and a design that emphasizes performance above other factors, I am left wondering what happens if you hook a pair of these directly to a high-quality audio source with balanced outputs? Do you need anything more to appreciate music at an audiophile level? Could you use five, or seven of these speakers to put together a brutally minimalist home theater? I would argue that such a combination brings one close to replicating a studio mixing environment at home, while satisfying the requirement of discerning audiophiles in terms of build quality and design. This is especially true in the case of the folded diaphragm tweeter - Emotiva states they will play near-flat from 30hz to 23,000 hz within +/- 1.75 - with specs like that, the only kind of subwoofer one would need is the sort that really brings an LFE track to life and can play down to 20hz or lower.
Edited by imagic - 2/6/13 at 7:50am
"Our amps are not simply monsters of power. Each is a true audiophile reference, with fully discrete design, extensive use of surface-mount parts, precision resistors and film capacitors. The transformer is a custom toroid for exceptional efficiency. Take a look inside the Stealth series monitors, and you'd swear you're looking inside a megabuck audiophile amp."
http://emotivapro.com/products/powered_monitors/stealth8.php
The Stealth 8 is a precision, bi-amplified active studio monitor that features a high frequency driver very similar to those found in speakers from GoldenEar and MartinLogan’s Motion line.
http://www.technologytell.com/hometech/92432/emotiva-pro-announces-stealth-8-precision-bi-amplified-active-studio-monitor/
. Why would you need that much power for a tweeter? Don't think anyone would ever use 1/8 of that power! Can this airmotive tweeter really play down to 30hz with authority? If so I can understand the 200watts but it also has a woofer?
