Does this driver show any promise?
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-514
•Dual 2 ohm, 2-layer copper voice coils
•Large vented pole piece and under-spider venting
•Black anodized aluminum former and black pole improves heat dissipation
•Thick, one-piece Nomex honeycomb covered cone with woven heavy-duty glass-fiber
•Tall-boy rubber surround for extra-long linear excursion without reducing cone surface area
•Dual linear stiffness spiders limit distortion and rocking modes
•Copper shorting rings and cap reduce distortion due to inductance variations
Cabinet recommendations:
• Sealed 3.1 cubic ft. (net internal) with 1 lbs. of Acousta-Stuf polyfill, f3 of 35 Hz with a 0.707 Qtc alignment
• Vented 6.0 cubic ft. (net internal, not including driver or port volume) with 6 lbs. of Acousta-Stuf tuned to 18 Hz with two 4" diameter by 26" long flared ports for an f3 of 22 Hz. Larger cabinets and lower tuning frequencies are possible. The largest recommended cabinet is 10.5 cubic feet tuned to 16 Hz using two 4" diameter ports that are 21" long for an f3 of 19 Hz.
Note: All parameters derived with voice coils wired in series.
PRODUCT SPECIFICATIONS
Power Handling (RMS) 800 Watts
Power Handling (max) 1,600 Watts
Impedance 2+2 ohms
Frequency Response 15 to 1,000 Hz
Sensitivity 89.5 dB 2.83V/1m
Voice Coil Diameter 2-1/2"
THIELE-SMALL PARAMETERS
Resonant Frequency (Fs) 19.5 Hz
DC Resistance (Re) 3.4 ohms
Voice Coil Inductance (Le) 1.31 mH
Mechanical Q (Qms) 2.40
Electromagnetic Q (Qes) 0.59
Total Q (Qts) 0.47
Compliance Equivalent Volume (Vas) 7.92 ft.³
Maximum Linear Excursion (Xmax) 19 mm
MATERIALS OF CONSTRUCTION
Cone Material Nomex
Surround Material Rubber
MOUNTING INFORMATION
Overall Outside Diameter 15.28"
Baffle Cutout Diameter 13.78"
Depth 7.55"
Dayton Audio UM15-22 15" Ultimax DVC Subwoofer 2 ohm Per Coi
Brand Dayton Audio
Model UM15-22
Part Number 295-514
UPC 844632099267
Product Category Subwoofers
Product Rating Be the first to write a review
Unit of Measure ea
Weight 28.0000
Impedance 2+2 ohms
Total Q (Qts) 0.47
Cone Material Nomex
Depth 7.55"
Brand Dayton Audio
Model UM15-22
Part Number 295-514
UPC 844632099267
Unit of Measure ea
Weight 28.0000
Also, you're only going to get maybe 1dB of extra "available low end" but use up more space doing so. This can be an issue for those with less space than power which is usually the case.
