AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › About to add a DVR into an existing AV setup.... help.... (semi-rookie)
post #1 of 9
A/V receiver............................ Onkyo TX-SR606 (yes, the one that has HDMI problems...)
TV............................................ Pioneer Plasma 5010
BluRay..................................... Panasonic
Cox Cable box
Harmony 1 remote
JBL and Polk speakers
And now adding a Panasonic DMR E80H DVR ( has hard drive and burner).........
About 4 years old. No HDMI... either component or S-video. Just purchased from friend. Just will use to record shows/sports to be viewed later. Will not burn HD content onto disc.
Just tried setting up...
*L/R audio out from Cox cable box to audio-in on DVR
*Audio out from DVR to audio-in on Onkyo receiver
*S-Video on cable box to S-Video on DVR
*Component out from DVR to component in on Onkyo receiver
Does this sound right?
After spending lots of time in awkward positions connecting everything, I'll wait 'til tomm morning to see if it all works....
Anyone have experience with hooking similar rig up? Any details/ideas, please jump in.... Thanks......
Edited by Beowulf1 - 1/31/13 at 6:36pm
post #2 of 9
Your hookup sounds right, assuming all settings are correct, but your terminology is a bit off. DVR stands for Digital Video Recorder,, which is what the cable co. supplies you with, aka "PVR," or "personal video recorder." Your Panasonic is a DVD Recorder, and is abbreviated as "DVDR."
post #3 of 9
Thx for reply.
I can't seem to get the unit completely working. The part of it that I care least about, watching DVD movies, works fine, but I use my BluRay player for that. Recording TV shows onto the HDD is what I can't seem to get straight, and that's what I got it for.
The E80H will not 'collect' any of my channels past 125, and I have many, many more channels with my Cox cable provider.
post #4 of 9
Originally Posted by Beowulf1 View Post
Thx for reply.
You don't record "channels" with your DMR-E80H, you record from the line input where the Cox cable box is connected to your E80H.
The DMR-EH80 is quite an antique, dating from 2003.
post #5 of 9
Thanks for your correction of my "terminology". Hence the thread title... from a "semi-rookie".
I've been fiddling with it.... not looking good. My buddy said I can return it....
Next problem to take care of.... sending in the Onkyo to Dave, the famous EBay repairer of TX-SR606 HDMI boards.... to fix the receiver issue.
Edited by Beowulf1 - 2/4/13 at 5:13am
post #6 of 9
Make sure the cable box is hooked up to the s-video "in" on the recorder, and not the s-video "out" - and the recorder's set to use that input.
If you can watch DVD's from the Panny through the Onkyo OK, then the problem must be before the Onkyo.
Edited by Rammitinski - 2/3/13 at 6:17pm
post #7 of 9
I'll try that tomm morning....thx.
Ravens.... Game score... SF > 2 turnovers, Ravens > 1 turnover, =Game, Set, Match............. Though I did think that was holding by the Ravens corner back in the end zone....
post #8 of 9
Exactly. That should take care of the problem.
post #9 of 9
The hookup worked. But, it's just a hassle to set up date/times for recording, not a simple/fast menu like Tivo.
What would be other alternatives to record TV shows to watch later? I think I saw on EBay a Tivo Series 3 TCD648250B unit with 'Lifetime Service Media' for about @ $300 I believe. I hate the thought of paying Cox any more money than I already do to lease a modern DVR....
Oh, a semi-hijack of my own thread (good at that)... I love the 'Hoppa' commercials with the folks with the Massachusetts accent... lol.
  Back to Forum: DVD Recorders (Standard Def)
